Whaler
I'm sure many guys have atemtted this conversion, and the bush came out quite easily but more often then not it is quite a mission, there are even some reel repair guru's that claim it has to be mashined out.
You need a tap set and a 6mm tap and a hammer...
Next, screw the tap into the bush about 4 turns until it grips the bush firmly,
Remove the tap set from the tap but dont unscrew the tap from the bush
Lock the square end of the tap into a vise or use a vise grip and tap the area around the casing with your hammer
Lastly take the new Bearing, part number is MR 95 and push in with your hand, no mashining nothing!
