Throw Baits - Scratching and Gully Trace
Trophy
The STD Gully Trace is a very versatile trace used to catch various small beach and reef species. Common trace used for scratching with small baits such as redbait, marine worms, white mussel, prawns, fish baits...
A small float can be added onto the hook snood or directly onto the hook shaft to add a little lift and movement to the bait presentation for certain species.
Hey Trophy
Some guys put the hook snood on the other eye of the swivel.
They told me it has a more direct feel on the bites.
Anybody tried it that way?
steve m
Nice Trophy!!!
@upcoming star I also do it the same way as trophy and have never had a probem feeling bites...
Anchorman
US, I also do it the way you suggested, the reason I do it like that is when you fish with small swivels, you can eliminate the chances that you can lose a fish due to the swivel popping.
@Trophy, I know a couple of guys who believe this trace is one of the best for Cracker, just shorten the hook and sinker snoots to 15-20cm and change the hook to a 7/0 or 8/0 and there you go. I actually caught a cracker on a trace like this, while fishing for Gallies with a 2/0 hook.
Trophy
Hiya Anchorman,
Either way would work.
Been watching the local Cracker chaps in action and will soon be posting a third Cracker rig...
Some thought behind floatation has 'popped' up!
Check the Cracker rigs post in the next day or two.
Regards,
T
raptor309
Going to use this trace this weekend! Cant wait.. scratch for some gallies!!
Is that nylon rope at the sinker? Which knot do you tie between your mono onto that nylon rope @ the sinker?
Thanks and tight lines! :wfish
JD
CaptainHookd wrote:
Hey trophy is it necessary to have that piece of rope by the sinker or can you tie a straight knot?
The piece of rope is there to stop your sinker line from bashing against the rocks and breaking off while you retrieving your line.
zkadir
Hi craigb,
Please excuse my ignorance, but can you explain or have a pic with the earbud solution?
craigb
Snip the ends of the earbud off...you are now left with a hollow tube...push your sinker line through and tie...you line going through the hole in the sinker is now protected by the plastic tube...wont snap off in the cast or cut against the rocks.
zkadir
Cool, thanks
zkadir
zkadir wrote:
Cool, thanks
So, you could also use a good quality straw? just cut to size?
#Barrackfishing
Hi, I see a lot of guys using a small red float with this rig, just above the hook. is this necessary? will it work better? I want to scratch for big blacktails….
Houtarm
Not necessary but helps give movement to the bait in the water, attracting fish.
Just take a few small floats in the tacklebag and try both with and without the floats. Some days the fish may prefer one or the other, some days neither, some days both.
::tight:
