Mr kite flyer wrote:
I was thinking of leaving it about 3m +- above the float so if suddenly disappears or starts moving up or down more than normal, could also help with setting the depth of your bait. It would also help you to determine if your bait is behind the back line.
To keep the electrodes wet i think glueing a small ball of cotten wool on top and wetting it would do the trick or hold it place with an elastic band. I must say this strobe is quite bright its like a disco light going off.
""Do you think by also putting a smaller one closer to the bait would help attact that big boy? I have read some where, flashing blue works best in deep water and green in shallower water.""
I have never done this before, i am waiting for those offshores! But any advice would be appreciated.
I have been toying with the idea ever since you posted the strobe,Dont know much about that discipline(or rather,know nothing),but it sure wont scare them nunu's away,would it?
If you are using the roller troller(pulley-rigged),everything safely behind backline,and you retrieve,maybe 20 meters or so,of kite line rapidly,wont it wet the switch again,and maybe, 'move" your bait a bit which cant do much harm.It is difficult to explain but ,my mind says if you retrieved a bit of kite line whilst your fishing-rod(fishing 2/rod-system) is pulley rigged,shouldn't you be able to generate slack on your "drop",enough possibly to get your strobe's wet-switch wet .(I see we have some experimenting to do,ha ha)
Think about it,I am finding it difficult to visualise right now,lol still early in the day.
