Not saying this is the only way, just the way I di
Not saying this is the only way, just the way I did it.
These plugs are actually quite expensive for what they are and anyone can make one with confidence it will work. Here is my method...
Step 1
1 - cut the nylon to size. I made mine 80mm long. I then squared it off on my sander.
2 - Then using a combination square, I found and marked the centre of both ends. I then used a sharpened pin that I made with a nail to lightly punch / mark the centre.
Step 2 - Drilling the holes:
What I did here, is a technique we use for drilling centre holes into poppers and stick baits.
1 - Put a centre pin in the chuck with the point inwards.
2 - Lower it down to the vice and clamp the pin in the vice. This ensures the pin is 100% in line with the drill press.
3 - Release the chuck leaving the pin secure in the vice.
4 - Put a small drill bit in the drill press chuck. I used a 3mm drill. You then place the nylon plug on the pin with the pin in that centre mark you made. Drill as far as you can into the plug, turn it around and repeat.
5 - I then used my hand drill with a 4mm drill bit and drilled from both sides towards the cetre. Here you can see our drilling was fairly accurate.
6 - Then with a 10mm drill bit, I drilled approximately 30mm into the back of the plug. A little less than half way.
Shaping:
1 - First U marked more or less where I wanted chamfers and simply sanded it a little at a time. Sand and turn untill it gets warm, let it cool then repeat. But it didn't get too hot or "melt" significantly.
Finishing:
1 - Made a fairly long loop in 1,6mm SS wire.
2 - Pulled it through the tail to its final position and marked the front so I know where the front loop must be.
3 - Then pull it forward as far as it will go. The loop I made slides all the way to the bottom of the 10mm hole I drilled.
4 - Made a loop on the front end.
5 - Pushed it back and to it's final position.
6 - Placed it in the vice and poured led in the back till it was full. I over did this slightly so had to cut some away.  :(
Cosmetics:
The last thing to do was fit some eyes.
1 - Mark out where the eyes must go. Not sure if you can see the pencil marks?
2 - Drilled some recesses.
3 - I have seen guys who use markers to outlining these recesses as eyes. I used 3D eyes though.
2 mistakes I made.
1 - I made the tow loop too big.
2 - I should have fitted a swivel on the front tow loop.
MrD
NICE NICE NICE.Bennie I used red glass beads with clear epoxy over them as eyes. Worked quite nice. Drilled hole just deep enough to press bead in flush and then filled with epoxy. The permanent marker seemed a bit "afskeep" werk to my liking.
Cool idea! Do you mind posting some pics for us?
sea sick wrote:
bennie
very nice and simple.
so, where can we source the white stuff?
ss
Maizy plastics is your best bet. Branches in most areas and they will cut to size for you. But don't ask for Nylon. Ask for Teflon which is the more common stuff used or HDPE which is much cheaper.
I have nylon off cuts, I can spare small quantities of 20X20X200mm pcs.
Ben REINERS
This is what most DIY enthusiast were waiting to see, & then came along the Master as usual to show step by step how its done :SSS Truly South African style:sa::thankie:first::respekt::cong:
And the best thing about it - its cheap to do ounce u have all the material :SSS
Good stuff as usual BJ.     :sval:((goodp_
Thanks Ben,
To be honest, this is very easy and if anyone wants to make their own lures, this is a great place to start. These are cheap, easy to do and they will catch fish!
@ Ysie, I lied... That plug weighs 55 grams including the lead. I'm not sure what it is without.
Fanie
Nice, and easy to make. I was thinking one could even put some reflective tape on a side or two just to give it that eye catching flash in the water.
The tape will come off if just sticked on, but you can keep it down with a few miniature screws. Of course if you make a thin recess and stick the refective tape firmly all the way round it should also last well.
Joker
Thanx Bennie.
I've been waiting for something like this.
now to get myself to buy those teflon pieces...
jeanmatt
Hi Bennie was wondering if you can assist?
Would like to know if you can provide some links, tips etc...
Want to start building some poppers, plugs, clone type lures. What is the absolute basic instruments/tools one needs maybe budget and materials.
If you can point out some site that offer tutorials etc that would be great, currently browsing 360tuna and stripers online wow!!!
Also your lure are sick, what ould you say would work for surf spinning?
Shizer sorry for all the questions!!!
Hi Jean,
No problem at all! That is what it's about!
What you need... Depends on how much money you have to invest! You really can start with very little!
Soft timbers mean you don't need heavy machinery! Use wood like Jelutong! The other thing to remember is that pretty lures catch anglers but not necessary fish! You need to start somewhere and your skills will develop as you go, so don't be despondent if the first attempt doesn't go according to plan!
Given a limited budget, this is the equipment I'd invest in, in order of priority... I would also start by making poppers and plugs because they are the easiest to make.
Wood lathe (Adendorf and Makro sell DIY lathes for around R1200)
compressor (A proper one... I've seen them at Makro for R600)
Disc sander (You can get one from as little as R650)
Airbrushes - You can start with cheap suction feed guns from R130 each (I actually like these for my base and clear coats)
Paints - Without a compressor or airbrush, rattle cans will work. Once you get into airbrushing you can use automotive 2K paints. Generally you can buy in 1/2 liter quantities and you can get by with just the basic colours. White, black, blue, red, yellow. Otherwise just buy what you need as you need it.
Take a look at this tut - Split body lures
Take a look here : Poppers These are made using A wood lathe, compressor and airbrush with very basic colours!
Any more questions, fire away!
Bennie
jeanmatt
Respect Bennie!!!
Cool ja reckon, I'll start with a couple of nylon plugs... Play around with shapes, sizes, color etc!
From there on I would love to start making some poppers etc
