Mr kite flyer
These floats are very handy if you want to send baits out to the backline using Kitefishers method discribed in his posts using the Roller Troller clip. These you use to take your bait out very easily as they are very bouyent but have enough weight to control the depth you want to keep your bait. I added a bit of weight by putting some lead in the side the is going to face down wards, i have found they should weigh about 1 kilo to do the job.
On the orange float, which i bought at a dive shop, i cut all their cables and clips off took the end caps off, added the lead, i then put a graphite tube (stainless tube would be better) through the centre so that your leader can run smoothly through the centre when you are varying depths on your bait. You can use the float to skip your bait on the surface or for jigging. I also find this method makes bringing in your kite much easier in strong wings.
