Kite Fishing
Mr kite flyer
This is my favourite kite. The Monster Kite from http://www.hiflykites.co.za This kite i use the most, 5km to 20km per hr wind, any higher you can go sking with it. No tail needed, but i some times add a small drogue 2m behind it which gives the kite more pull and makes it even more stable when tacking into the wind, i have had it close to 50 degrees. Takes 20 secs to set up and a match stick to tack it, you do this by puting a catspaw knot in the bridle rope the opposite side you want to tack the kite, and up you go for a quick test run. i will put some pics on other kites some from New Zealand at a later stage.
I dont like long tails on a kite especially on the rocks they tend to get in the way for me anyway.
kitefisher
Like you said Kite Flyer, a man needs a kite,or is that a boy,needs a kite. LOL
These are a few pics of different-sized Square kites,these are from Windsong Kites,South-African made. They vary in size from 600mmx600mm up to 1000mmx1000mm.
kitefisher
Some more Kites,Australian manufactured .These kites only have two vertical spars ,fairly soft ones at that.They use a drogue as a tail.
