rofflign wrote:
some of the distances mentioned are pretty impressive,although I think if you can cast a bait 100 to 120m you've pretty much got it covered,if you really need to get further go for a wade...casting far from chest high water is another skill all on it's own.the quickest way to increase distance is to lengthen the drop to about 2 to 2.5m and adapt to a side cast or pendulam and get the whole body behind the cast, which enables you to cast using thigh and back muscles.
SPOT ON, if you can cast a long drop and get a big build up you will, not should increase with at least 20 meters end more.
But it takes practise I do the off the ground,and over head cast.I prevere the swing back and then the build up to the cast.
If you plan on practising use .55 line a heavy line on practise will give you a stronger cast with lighter line.
I fish with .55 on our coast ,but will drop to 35 for plugging and spooning.And if you are
right handed it is the left arm that gives you youre cast.
A rod can be devided in 3 parts Number 1 the bottom end 2 is the middel end and 3 the last third.
When you cast the power starts at number one, then jumps to 3 and the last follow through is number 2.that is the way youre rod reacts to youre cast.
