My way of splitting a Galjoen and getting it ready fora braai.
You will need a cutting board scissors and a knife. I prefer a knife with a rounded point as its easier to control when cutting
Galjoen defrosted or fresh from the sea.
You are going to start cutting from the tail towards the head, all along the dorsal fin (on one side only).
Insert the knife and start cutting. make sure the blade is running on the bone (spine) of the fish. Do not cut all the way through to the belly skin.
Continue with the cut all the way to the head and also through the head.
It should now look like this. Cut from the tail to the mouth.
Use the scissors to cut the ribs if they are to tough to cut with the knife.
Galjoen split into 2 but still one piece on the belly side. remove the insides (guts) and wash clean.
Not cut through the belly. Now ready for spice and braai.
Fire it up
And away you go
Fire it up
And away you go
