benniejordaan
Hi guys,
So Tauruck "the man" has shown us how to make moulds! I have been experimenting with different materials and it has been a long process. I found that although it is easy to cast resin or some of the plastic composites, there is a need for a popper or stick bait that either floats or needs to be weighted to give different actions in the water.
One of the materials I have been experimenting with is foam. I have used various polyurethane foams and one material in particular is RX66F from Resichem. This is the same stuff used to make saddles so it is tuff but still floats.
Here is a before... Foam popper. This one has been weighted 1 oz in the mid section and sits 2/3 under water and level. A barrel sinker was loosley tied to the main wire so it lies in the belly. No need to bopa it on because the foam holds it in place.
